Drag Radials on 20in. Saleen Rims
Sup all,
[/align]
[/align]New to the forums, just recently purchased an '06 SCS281. I would like to get some drag radials for the car, but I am having trouble finding 20in. drag radials. I would like to go ahead and buy 18in. rims all around and get some tires for the front and drag radials for the back. Questionwould 18in. rims fit on the front considering the 14in. rotors? If not would anyone no where to get 20in. drag radials? Any info is greatly appreciated.
[/align]
RE: Drag Radials on 20in. Saleen Rims
I dont think anyone makes a 20 in drag radial , I did hear that Nitto was working on one. I face the same issue you do. Buy some cheap rims (18inch) and put some drag radials then when you go to the track.
The front 20" wheels are 30mm offset. The rear 9" wheel is a 40mm offset and the rear 10" wheel is a 50mm offset. We use the same offsets on the 19" Parnelli Jones wheels and that car uses the 14" brake kit. We have yet to fit an 18" wheel onto a car with the 14" brake kit so I'm not sure if you would clear the brakes. Clearance to the brake kit completely depends on the inner profile of the wheel.
mungodrums
09-28-2015 10:54 PM
09-15-2015 07:34 PM
