mod job ? HELP
sup guys ok so i talked to my guy at the shop im doing my mods at today and he said it was gonna be bout l100 bucks to install pully pump cai 373 gears TB MAF DYNO AND TUNE my car...does this sound about right for u guys that have been this road???this doesnt include parts..??thanks im on the ropes!!!!!
RE: mod job ?
Sounds dirt cheap to me, a Dyno tune is about $75 per hour a good tunercan tune it in about an hour, so you figure the rest of it is $25, and gears at a minimum are $150, sounds to good to be true, but if he reputable, you can take my advise with a grain of salt.
RE: mod job ?
ORIGINAL: NastyGT sup guys ok so i talked to my guy at the shop im doing my mods at today and he said it was gonna be bout l100 bucks to install pully pump cai 373 gears TB MAF DYNO AND TUNE my car...does this sound about right for u guys that have been this road???this doesnt include parts..??thanks im on the ropes!!!!! |
RE: mod job ?
dang my fault guys i ment 1100 dollars for all labor install fuel pump gears pully intake maf throttle body spark plugs and dyno and tune
RE: mod job ?
ORIGINAL: NastyGT dang my fault guys i ment 1100 dollars for all labor install fuel pump gears pully intake maf throttle body spark plugs and dyno and tune |
RE: mod job ?
Believe all my work was around$1300 labor/$1700 parts
RE: mod job ?
Mine ended up at $860 for parts (Xcal tuner, wideband O2 sensor, chicane pulley, SVT pump, and 3.73 gears.
Labor and dyno time totalwas around $2k....but I got some baseline runs in and an overall data logging session as well. My guy is on the high side, though. |
RE: mod job ?
the gears pully and pump 420
Cai190 TB225 MAF200 so bout a grand i guess but he said i may need new injectors but i didnt think so and im gonna get ngk tr6 plugs but do u guys think i really need the TB right now or what???gosh this stuff is killin me its all bout the $$$$$$$$:D |
RE: mod job ?
If you're wondering about your throttle body.......measure it vs. what you're looking at upgrading to. Also, take a look at the supercharger intake bore. I'm not sure, but this may not be any bigger than 70 or 75 mm. Different brand throttle bodies may flow a little better than others. If you are pressed for money though, I wouldn't spend $225 + labor to have a 5 mm larger throttle body (assuming you go from 65 to 70 or 70 to 75). My$0.02 ;)
RE: mod job ?
From the replies it seems you are in the range. My only comment is never look for a "deal" with your Saleen. The $200 you save will be quickly forgotten if the job is not done perfectly. Get it done right and if its less, great!
