Custom Flowmasters w/ Dumps finally here
RE: Custom Flowmasters w/ Dumps finally here
ORIGINAL: cobraT
The part # for the muffler matching the sizes he posted. Flowmaster Model #9425432 40 Series Delta Flow 2.50" Inlet/2.25 Dual outlet,,
http://www.flowmastermufflers.com/pr...oducts_id=3401
cobraT the mufflers you are looking at are the one with the single inlet being on the side instead of the middle. It would not fit with our set ups. Just letting anyone know, the flowmasters are a bit longer than the magnaflows so there isnt a lot of room to play with.
Hey Carp so the muffler we need to get with the single inlet needs to be in the middle not the side??? Just clarifying that...Why didn't you go with a super 40 series??
ORIGINAL: thcarpen
ORIGINAL: thcarpen
Let me know where it is, and Ill be there.I promise I will have a sound clip sometime. I just need a good camera to show it.
[quote]ORIGINAL: 06S281
[quote]
Yes: you need the one in the middle. If you look at the pictures that are included in this thread, you will or should see that it comes in the center of the muffler. The reason I went with the Delta Flow 40's is because with the way the saleen exhaust is ran and the sizing of the pipes, everything fits in a lot cleaner. If you were to go with the original 40's the diamater of the muffler is way too big and you will have to have a lot of pipe reductions made. It wont be that clean of an install if you go with that set up.
[quote]
THese posts are useless without video clips....[8D] Please.....
ORIGINAL: jadeat
Thanks Carp for providing those Flowmaster model numbers. I went today and had them installed. The soumd is so much better than the stock Magnaflow's.
