SEMA
Is Saleen not at SEMA this year?
RE: SEMA
Saleen has only had a booth at SEMA on one occasion.
We have 3-4 cars there currently at other vendor booths and afew cars there that we worked on in the american racing and possibly the ford booths. We do have a ton of reps and engineers at the show checking out all the new products though. |
RE: SEMA
WOWZ i want to hear this ram/supercharger yah its carlo's ram system I really dig how saleen keeps up'n the ante notes: The new high flow cast aluminum inlet top has a larger cross sectional area, an improved bend radius, and a shorter path creating virtually no restriction. It also has a larger throttle body flange opening to accomodate a larger OEM and aftermarket throttle bodies. The injection molded lower air box features and enormous 115mm mass air flow sensor, capable of supporting huge HP numbers. The high flow green air filter boasts %50% more area than the standard air panel filter. All of these items prodide a huge advantage in reducing the vacuum before the supercharger. The big story however, is the ram-air scoop sticking out of the hood. By moving the intake outside the engine compartment and up into the air stream running over the car, Saleen was able to actually pressureize the air coming into the intake. Testing has yielded pressures or .25 PSI at 80 mph. Aditionally this is pure cold air comin into the engine. Lastly the cast aluminum shaker hood scoop looks awesome sticking out of your Mustang hood. |
RE: SEMA
Address got blocked out...
RE: SEMA
If it's Carlos' car with the functional ram air and the supercharger then it sounds INSANE!!!
RE: SEMA
So yes, probably our best kept secret for SEMA is the SpeedLab Shaker Supercharger! We should have more info on it for you very soon!
RE: SEMA
Nice!
RE: SEMA
Please keep us posted on the availability of the Shaker Supercharger! Every time I think I have decided what Sakeen upgrade to do next, a new and tantalizing option becomes available. This is the kind of problem I like to have. :D Keep up the good work!
RE: SEMA
Damnit I just got the larger intake tube. Oh well maybe for the spring
RE: SEMA
Yah I'm kinda disappointed now too[:@] Cause that is pretty sick!
