air temp running really hot with saleen blower
RE: air temp running really hot with saleen blower
I would say its the black box as casey and jim said, those things take a dive quite often, the water pump is a sealed design and usually last for a quite a long time.
High SuperCharger Air Temp
Here is the installation manual, which should remind you of the location and details of therecovery tank, heat exchanger pump and hoses and other areas to trouble-shoot. http://www.saleen.com/installation-m...%20Rev%20G.pdf
Have you noticed any leaks? My h/e was taken out by a rock and once the fluid leaked out the temps shot right up. Unless you are just experiencing temporary heat soak, my guess would be leaky exchanger or bad pump. Good luck andlet us know what you find out.
What ended up being the problem?
They are right "the black box as casey and jim said, those things take a dive quite often, the water pump is a sealed design and usually last for a quite a long time."
My 2007 had this issue. Saleen was GREAT they have a Service Bulleten: TSB08-010PDF Sheet with a work around. A 5 Amp fuse 6 amp Diode connects to Green and white in Harness other end to Brown. If your SC pump is not working check the black box on passenger side fender marked with Saleen sticker.
09-16-2015 02:11 PM
DrunknRuckus
08-23-2015 10:05 AM
