Big trouble with rear end?
Jazz is right But the stock panhard bar probably is bent. When you lower a S197, the rear end will shift to one side. The Saleen S197 springs do not lower that much. The rear only shifts at the Most 1/4". That's why Saleen really never changed them. IIRC , the limited ones that Saleen made for some E's, were the same length as stock.
The car does have to be parked on a flat surface. It is hard to really tell with your pics, but it almost looks like the axle snapped (c-clip) and the rotor/caliper are holding in place??
Casey
Casey
Yeah, this is the first time I have noticed it, and as far as it is out, I'd like to think I would have noticed it sooner. I was trying to avoid going away from anything stock, but this is certainly not something I can live with. lol, I'm a perfectionist. At any rate, I am going to go see if I can get the car on a lift, and see if I can find anything.
Casey
Casey
Well, I crawled under the car today and found nothing out of the ordinary. I have still been unable to get my car to a lift to get a better view, though. I Did take the car out and cleaned it up today, and parked on a few different 'flat' areas to get an idea of how bad it really is. The car seems to drive and launch fine. On some areas it looked far worse than on others. On every surface i tried, the differene was noticeable though, just by standing in the front of the car and looking at it. I also went back over all the tire pressures to make sure i was dead money there. It almost seems to me that the passenger side wheel is tilted in at the top like this: \ . Against my better judgement I am going to take it to the dealership this week and have them align it, and see what their opinion is. Thanks for all of your help guys. And also, I may end up going with some aftermarket parts. sftdyna, where did you get your techo from? Say I were to do some changing in the rear, what would be a cost efficient setup that I could easily swap back to stock if need be? If there is no unseen damage, should I just get an adj. panhard and call it a day?
Also, I tried to get some better pics to put the difference into perspective...
On each of the pictures, I used a flat edge ruler and a level to make sure the flatedge was level and against the fender....
Driver's side, the rim sticks out 3/8" PAST the fender:
Passenger side, the rim is inside the fender 7/8":
Ugh.
Ugh.
Ugh.
Ugh.
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
