Weight of the Saleen 7-spokes?
If I remember correctly the front wheels were 37lbs while the rear wheels were 42lbs. Thats rim and tire. Basically they are VERY heavy. Hence why they came with the forged 5-spoke design. The 7-spoke were cast wheels.
So you can save weight with certain wheels AND tires.
Tirerack says the rear tires are 35lbs and fronts are 31lbs. That cant be right, is that with the rim?
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
scroll down to 275/35/20 and 275/40/20
The Tire Rack doesn't list the rear 275/40/20 size in the PS2, but even the heavier 275/45/20 PS2 is a significant 6 lbs lighter than the Pirelli 275/40/20 rear tire.
You'll obviously save more weight with forged wheels vs. the cast 7-spoke wheels, but don't forget you can save some weight when deciding which tires you buy!
