Boost Gauge install
Boost Gauge install
OK been searching the internet all night and did a search on here and I need help with what line to tape into for the boost gauge. I have the wiring no problem, background is in wiring aircraft. I have read that it is the fuel pressure line but not sure which one that is. Can anyone past a couple of pictures of the line I need to use.
2005 4.6 with M90.
2005 4.6 with M90.
I tapped mine into the fuel pressure - manifold vacuum line. On your first pic, this is the vacuum line running across the top of the fuel rail that turns into the 90* brass fitting on the intake manifold. I believe this is how Roush plumbed the boost gauges at the factory as well.
Well, I'm about to do that one, so let us know how it goes (specifically, where to tap in for switched power). Thinking about going with the Glow Shift oil filter sandwich for the sensor.
http://i227.photobucket.com/albums/d...cture005-2.jpg
