Is there a fuse that controls the a/c and heater controls??
I had to take out the radio again to add to the sound system.... Disconnected the battery and everything... But when I reconnected everything the climate controls do not light up or work at all... I tried checking all the fuses, but they all looked fine. Any suggestions as to what could be wrong?
I may be late. Don't know if youre still around but i am having the same issues. Hope you found an easy fix.... My climate section in the center panel doesnt light up or work for that matter... ... fuses have power... i unplugged and replugged them... im at a dead halt... it all hit the fan( no pun intended ) when i disconnected the battery and reconnected it
Anyone figure out the fix for this issue? The heater in my 2014 Mustang comes on by itself full blast on the windshield and I can't turn it off or adjust any settings. None of the buttons on the radio/climate control console light up or do anything when pressed. At least I can adjust the radio via the steering wheel controls but no luck with climate control.
