64.5 260 problem
Old 10-08-2010, 10:21 AM
dpellicone
dpellicone's Avatar
Default 64.5 260 problem
Guys and Gals, looking for some input on a issue with my 260. The car will start but when it is put in gear it run but will not accelerate. It has a rebuilt carb, new plugs, wire etc. The heads have been off and totally rebuilt valves replaced etc. New fuel tank, fuel filter.
Any thoughts?
Thanks
dpellicone is offline
Old 10-08-2010, 12:34 PM
2+2GT
2+2GT's Avatar
Accelerate as in it starts to misfire like crazy?
2+2GT is offline
Old 10-08-2010, 12:55 PM
dpellicone
dpellicone's Avatar
Yes Sir! Starts to accelerate then just cuts off.
Old 10-08-2010, 01:56 PM
2+2GT
2+2GT's Avatar
Well, most likely it's an ignition problem. Even if the accelerator pump in the carb was inoperative, you could accelerate, just not real hard. Check dwell, condenser, and coil.
2+2GT is offline
Old 10-08-2010, 06:49 PM
67t5ponycoupe
67t5ponycoupe's Avatar
Also check the diaphram on the vacuum advance. If the diphram is ruptured it will cause that problem.
67t5ponycoupe is offline
Old 05-28-2017, 10:37 PM
sremle
sremle's Avatar
I had a condenser act like that on a SOB (Some Other Brand) car back in the 70's. Did you ever figure it out, since this was over ten years ago?
sremle is offline
Old 05-29-2017, 09:39 PM
Gun Jam
Gun Jam's Avatar
Dude I know 6 post are rookie numbers but there are better ways to pump them up.
Gun Jam is offline
Old 05-30-2017, 07:09 AM
sremle
sremle's Avatar
Some guidance here would be better than threats.
sremle is offline
Old 05-30-2017, 07:12 AM
sremle
sremle's Avatar
There never was an answer here to the problem. Means it never god fixt?
sremle is offline
Old 05-30-2017, 10:34 AM
Gun Jam
Gun Jam's Avatar
Read the Private message I sent you
Cheers
-Gun
Gun Jam is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: 64.5 260 problem
