2005 V6 Starts but dies in a few seconds
Hopefully someone can shed some light on this problem I am having with my 2005 Mustang V6. It just died on my wife and after towing home I cannot get it to run. I thought maybe it was a fuel filter so I changed that with same result. It will start but only run for a few seconds the n dies. Feathering throttle does not help nor does giving it gas. Any ideas would be welcome.
Thanks
Thanks
funny you should mention that, my car wasn't running right then the dreaded wrench came on and car died. so I stopped and plugged in my sct and mysteriously wrench gone! It started up and ran fine. got home looked under the hood, somehow a wire in the maf wiring harness had a cracked plastic connector and it was grounding out. put new connector on taped it up and put new conduit on it, and its running like a champ.
Well the first thing that happened was it died at a stoplight all of a sudden when my wife was driving. I was able to get it started and got about 1/2 a mile and it bogged down and died again. It has not started but for a few seconds since. I have checked all the fuses, cleaned the MAF, changed the fuel filter and still no run. The car has about 50k on it and has been completely trouble free from day one until now. Bummer because the weather is starting to get nice.
Try checking the charging system - when you turn the key to "on" not start what is the draw - then try to crank it over. Are any other systems acting up - lights, dash, radio?
The symptom sounds a lot like when my alternator went out.
My CD player and dash lights reset sometimes when I turn it over. I am also showing a tire pressure sensor fault but that could be because I disconnected the brand new battery (installed a month ago) to have it checked. Do you think this would cause my car to crank over and not start? I will take my alternator up to Autozone to have it checked just to be sure. Thanks for your input!
So a bad alternator could cause a no start problem? I have a pretty strong battery though. Funny thing is it will start the first time you turn it over then die in a few seconds. Any subsequent tries it will not. Starting to think maybe it is fuel related. My wife bought a half tank of gas about 10 miles prior to the initial stall. I tried to siphon the tank but there must be a check valve in the filler tube. I am not sure how to drain the system safely.
I'm starting to notice my radio is having issues as well, sorry to hi-jack but instead of creating a new thread I think this is pretty close to what I'm experiencing. I notice when i come to a complete stop or even sometimes just by slowing down, my stereo will cut out but, when I'm rolling or at highway speeds its working just fine. Never had this issue before. Could it be the alternator going bad?
