4.0 liter engine quit,s
Old 09-25-2016, 08:02 PM
Terryw
Terryw's Avatar
Default 4.0 liter engine quit,s
We have a 2006 with a 4.0 v6 automatic transmission, it quit,s at random when slowing down no ck eng, light. One time I did notice the wrench symbol on the dash was on. It has no codes and other wise runs fine about 70'000 miles on it we have had the vehicle 1 year now. It happens after it has been driven for at least 20 minutes. Anyone have any idea,s I,m a heavy truck mechanic & not that familiar with auto,s
Terryw is offline
Old 09-25-2016, 08:13 PM
99GTvert
is my username.
99GTvert's Avatar
Damn thats scary. Connections tight on the battery? Was any work done to it recently? Any ignition parts serviced/replaced?
99GTvert is offline
Old 09-26-2016, 12:34 PM
JJHoover
JJHoover's Avatar
my mustang does it every now and then, I still have no clue why
JJHoover is offline
Old 09-26-2016, 09:09 PM
jimkaray
jimkaray's Avatar
Possibly the TPS (throttle position sensor) is the culprit. I had similar symptoms quite a few years back and after swapping the TPS it hasn't reoccurred.
jimkaray is offline
Old 09-27-2016, 10:46 AM
movielover40
movielover40's Avatar
Does it start right back up after it stalls?
movielover40 is offline
Old 09-27-2016, 07:18 PM
Terryw
Terryw's Avatar
Default 4.0 engine quit,s
Every time but once it will start up & run fine. One time it started & quit several times as we coasted into our driveway. I don,t think it,s an engine issue or it should have set a code. If I monitor engine functions everything looks normal except timing is bouncing about a 10. Degree span
Terryw is offline
Old 09-27-2016, 08:49 PM
Stangbass
Stangbass's Avatar
My 2010 manual used to do something similar on rare occasion. I would clutch in come to a stop and rpms would drop right to the floor. IIRC mine was an exhaust leak on a cheap set of headers. It was also accompanied with a hunting idle.
Stangbass is offline
Old 09-28-2016, 10:37 AM
movielover40
Might be a faulty mass airflow sensor.
Old 09-29-2016, 08:44 AM
rls82959
rls82959's Avatar
There is a technical service bulletin for 05-06 fuel pumps.
TSB 06-09-09
This TSB is for vehicles stalling out after coming off a long highway drive.
Probably not your issue, but then again ..........
I know the tsb is for hesitation, but I seem to remember several posts about stalling out after a long drive and it ended up being the fuel pump. Good luck.
rls82959 is offline
Old 09-29-2016, 01:46 PM
Here's a list of known issues (TSBs) https://lmr.com/products/2006-Mustang-TSB-Recall I don't see any matching your exact description but I agree with RLS, Fuel pump related ones sound the most legit 06-9-9. It could be that yours skipped the hesitation and went straight to failing/leaking.
Quick Reply: 4.0 liter engine quit,s
