4 Speed With 3.0 or 2.79 Rear End?
Old 05-04-2017, 12:48 PM
guitarman376
guitarman376's Avatar
Default 4 Speed With 3.0 or 2.79 Rear End?
I just hooked up a tach in my car for the first time, and I was shocked to realize my car has either 3.0 or 2.79 rear gears (I think 2.79). I haven't had a chance to check out the ID tag if there is one but its definitely one of those two ratios. I know my tire height and used a calculator to figure out what rear gears my car has. Currently the car has an FMX.
I am going to eventually swap to a wide ratio toploader, but with what I know now I am worried this won't be the best combination. Basically I wanted to hear from anyone that has a 4 speed and gears like this to see how they feel about their setup. Anyone?
Otherwise I will have to save even more to rebuild the rear end at the same time I do the toploader swap. For something that sees the freeway a decent amount I will eventually go to 3.25. My motor is stock, but will eventually have a carb I/H/E but that's it (maybe an extremely mild cam one day). I mention this so that you know the powerband is low-end just like the 351w's came from the factory.
guitarman376 is offline
Old 05-05-2017, 12:04 AM
Starfury
Starfury's Avatar
I started off with a 3sp and 2.79's. Cruised great on the freeway, but was always a dog off the line.
I changed to 3.25's after the 331 build and noticed a huge difference in acceleration. Cruise rpms went up to ~3200 @70mph, which is OK for the motor build.
Swapped in a close ratio toploader and I absolutely love it. First is a dog, but once it's rolling it's a blast.
I think you can get away with the gears temporarily, but it should be OK with 3.25's if you really want to drive it on the freeway.
Starfury is offline
Old 05-09-2017, 09:05 PM
guitarman376
I am thinking that as long as I continue running a cam that makes power off idle to ~5000rpm it shouldn't be too bad to start from a stop. The thing is, I really like the gearing I have once you are moving...
Old 05-17-2017, 08:44 AM
Nosara
Nosara's Avatar
Default 2.79
I ran a 4 speed toploader with a2.79 eight inch open for years. It did just fine. With that gear box you can make anything snappy. Lot of fun and I even autocrossed it way back when. Second gear was perfect for AC runs.
Nosara is offline
Old 05-20-2017, 03:40 PM
guitarman376
Good to hear fellas. I want to put off changing anything in the rear end for as long as possible. I have been asking any and all questions regarding toploaders etc for a while now, even though I am not yet at the stage to start the project...I'm a planner for sure.
Old 05-20-2017, 11:03 PM
Starfury
Starfury's Avatar
Better than the other way around It's never fun when you get halfway done with a project to find out you need to redo parts of it, or completely replace a related system because it's not compatible.
Starfury is offline
Old 05-23-2017, 07:30 PM
drewsky
drewsky's Avatar
had a 3.0 with my 4 speed prior to the 3.25 i put in it now. the 3.25 is my favorite gear for classic mustangs. but the 3.0 was not terrible at all
drewsky is offline
