side markers not working
Old 05-09-2017, 09:16 PM
skymax04
skymax04's Avatar
Default side markers not working
i just changed all 4 of my bulbs for my front and rear side markers...none are still working...any ideas? 2006 gt
skymax04 is offline
Old 05-11-2017, 05:17 PM
07 Stang
07 Stang's Avatar
Hmm...I wonder if you have a water leak that is causing electrical gremlins. Check the carpet on your passengers side. Feel to see if it is damp or wet. If it is.....then your SJB is probably toast.
07 Stang is offline
Old 05-11-2017, 07:32 PM
skymax04
skymax04's Avatar
thanx for the response..everything is dry and everything else works...all the fuses are good..at this point i have no idea what else to do.
skymax04 is offline
Old 05-12-2017, 04:36 PM
skymax04
skymax04's Avatar
Ok so I did this and under the carpet is soaked...what do you think it from?
skymax04 is offline
Old 05-21-2017, 05:01 PM
07 Stang
07 Stang's Avatar
Do a search on Leaks in this forum and you will find many causes unfortunately.
07 Stang is offline
Old 05-21-2017, 06:36 PM
Gravydog316
Gravydog316's Avatar
Yeah the S197 can get drain problems if you aren't diligent;
search on here,
& check the 2 drain bags under the hood
Gravydog316 is offline
