tire mix, new G-Force Comp-2 with old Nitto Invo
Old 05-23-2017, 09:56 PM
kevsgt
kevsgt's Avatar
Default tire mix, new G-Force Comp-2 with old Nitto Invo
Need to replace a flat tire. Currently have Nitto Invo tires that came with my wheels (2010 GT500 style 18x9), which have about halfway worn tread. Size is 255/45-18. Wanted high performance summer tires. Couldn't find a lot of options in that size. Will I be alright with 2 new BFG G-Force Comp-2 A/S tires (255/45ZR18), installed on the rear, and keep 2 used Nitto Invos in the front?
kevsgt is offline
Old 05-24-2017, 07:50 AM
Stoenr
Stoenr's Avatar
That should not cause you any issues.
Stoenr is offline
Old 05-24-2017, 02:30 PM
Should't be a problem. I can't rotate my tires because they are staggered so I usually replace the rears about twice as often as the front and one set or the other is always discontinued.
Old 09-05-2017, 05:28 AM
audioAl
audioAl's Avatar
I just replaced my Perilli rears with Bridgestone pole position S-04's 255/45/18 and enjoy the added grip after BMR camber bolts, 4pt. brace and alignment to 1.5 neg camber. No trouble here.
audioAl is offline
