99 Mustang GT A/C issue
I own a 1999 Mustang GT SOHC. When my engine is running (of course) and I first turn on my A/C the clutch engages, the compressor spins, and the engine idle drops. After a few seconds the engine idle goes higher and the compressor turns off and will not come back on.
I have replaced the Clutch cut off sensor, compressor (was bad), and did an Evac/recharge. I was told the liquid line that hold the oriffice tube may be clogged. I removed the line and I can blow air through freely. Any ideas?
Welcome to the forum.
I'm no AC guru, but I'd personally just take it in for service. It might hurt the wallet some, but at least you'll have AC again. And I'm sure that's kinda important in Florida.
Good luck
Good luck
That's the thing. I work in a shop with two Master Techs lol. It is 100% an electrical issue. I have no dash lights and my gauges "reset" every time I start the car. Like, go from off to all the way up, back to off then to where they need to be.
Thats how the gauges work, they do an initial sweep at key on, then return to normal.
The newer cars maybe do the needle sweep on regular startup but not the older cars. The 99 would only do that if you held down the trip reset long enough while turning the key to the 'on' position.
Are there any other electrical issues on the car? Is the car battery still in good shape?
I did a little research on it and it seems that when the battery is failing or there is a bad ground they will sweep.
This could very well cause problems with the A/C cycling off. A bad battery can cause all kinds of trouble with the engine management system so it somthing to look into.
