2002 Mustang GT Electrical Issue
Hi all, my 2002 Mustang GT has been giving me some problems recently. Within the last two weeks I repainted my front fenders myself, but while I had been painting them the car was out of cover and got rained on. I didn't think much of it at first but then I realized my CCRM (Constant Control Relay Module) was uncovered and could have possibly suffered damage.
When I put the car back together nothing seemed wrong and it drove for 2 days with no problems at all. But on the second day my dome light fuse popped as well as my reverse light fuse. Then, my car started sputtering in a drive thru line later that day. Then it made a few huge loping sounds as if it had massive cams. After that it died and did not start again. The car cranks but does not get fuel, therefore it does not start. I had to push it out of the drive through with my girlfriend (bless her poor heart). I switched the key to the in position and cannot hear the fuel pump priming.
I had just replaced the fuel pump 3 months ago and it has been running strong so I do not believe it is the fuel pump that is the problem. So this made me check the fuel pump fuse, which was blown. I replaced the fuse and still nothing. So I used a multimeter to check the power and I got power all the way up to the CCRM but nothing after the CCRM. So I ordered a new one, which I will be replacing next week. But I don't believe that this would cause the dome light and reverse lights to go out.
- What could the problems be with those fuses inside the car?
- And what could have made this problem occur? (Rain water or unrelated short circuit)
- What can I do to ensure this problem does not occur again?
It ended up being one of the wires to the fuel pump was severed and was shorted out. Completely unrelated to the CCRM which was weird. But I had to pull the whole carpet up to find the wire that was causing the short circuit.
