Need ideas for speaker upgrade 2015 Convertible Mustang GT
Old 07-20-2017, 01:45 PM
Nytehawk03
Nytehawk03's Avatar
Default Need ideas for speaker upgrade 2015 Convertible Mustang GT
Hello all
I just bought a 2015 Convertible Mustang GT and would like to upgrade the speakers. I have the 9 speaker system (no subwoofer or rear speakers compared to the 12 speaker system).
I would like a system with good clean sound and can handle reasonable volume but don't really want a sub that makes my trunk vibrate.
I've been searching for specific advice for 20+ hours and haven't found anything specific to convertibles (all the prefab subs are designed for the coupe).
Do any of you have advice for a speaker, sub, amp upgrade (I want to keep the head unit) for $1000-2000?
Thank you in advance!
Best
Nytehawk03 is offline
Old 07-20-2017, 05:33 PM
Spork3245
Spork3245's Avatar
I would go with Kenwood or Infinity brand speakers of the proper size and channels to replace each stock speaker. In regards to subs, they make boxes specifically for convertibles which fire upwards, I don't know if there are any for the S550 Mustangs, however. A strong sub will make the trunk rattle, there's no way around that - you can buy taping and foam that lines the creases of the trunk to reduce/eliminate rattle. This is all coming from the experience of re-doing the speakers of my 2001 GT Convertible about 10-12 years back.
Spork3245 is offline
Old 07-20-2017, 06:52 PM
Nytehawk03
Nytehawk03's Avatar
Thanks Spork!
I have not found any sub boxes for the convertible S550 yet but will keep looking. Maybe I don't need a sub? Has anyone just upgraded the 8 speakers (I probably won't upgrade the center speaker) and the amp and ended up with decent sound?
Old 07-23-2017, 12:01 AM
Spork3245
Spork3245's Avatar
Originally Posted by Nytehawk03
Thanks Spork!
You could always see how it sounds without the subs, then get some if you need more bass. Don't forget that adding subs to a convertible tends to make the trunk semi-useless.
Old 08-27-2018, 11:43 PM
Kurt Eischen
Kurt Eischen's Avatar
I am in the SAME boat,. I have been searching and searching. Crazy. Hopefully someone responds with what they did .
Kurt Eischen is offline
Old 08-28-2018, 12:39 AM
OlPal
OlPal's Avatar
Smile Try This
At the risk of angering forum mods.....
I always go to Crutchfield.com for my car Amps, Speakers, They provide instructions & install parts when you order..
OlPal is offline
Old 08-30-2018, 07:10 PM
Grumpy Old Man
Grumpy Old Man's Avatar
+1 on Crutchfield, They are great for home audio too.
Grumpy Old Man is offline
Old 08-30-2018, 07:20 PM
08'MustangDude
08'MustangDude's Avatar
In my S197, I put Kicker 6x8s up front, Infinities, rear. The Kickers are 4-ohm, but the infinities
are 3-ohm. Only needed harness adapters, the speakers bolted in with no issues.
08'MustangDude is offline
Hinojosa
04-03-2012 02:33 PM
Cali209
10-05-2009 03:01 PM
MnT
10-23-2006 01:34 PM
klispic
02-12-2005 10:08 PM
ultimate_008
08-07-2004 08:37 AM
Quick Reply: Need ideas for speaker upgrade 2015 Convertible Mustang GT
