Front Crossmember
Front Crossmember
Grouper, To avoid jacking my 2014 GT from the front. A trick I learned, circle racing is to jack the car from the side, like NASCAR pit crews do. I also installed "frame rail extenders" so I can jack from almost any point. To specifically answer your question, it may be OK, but I would avoid any lifting from the front end suspension items. Can you jack from your front frame rail from the side?
Front Crossmember
IMP, you caught me again. "frame rail extenders" is a term we used when doing serious suspension upgrades on our sexties Camaros.
What I meant in Mustang parlance was "Subframe Connectors."
Sorry, just another Senior moment.
I have printed out a lot of jacking points for the car. The center of front cross member is one. I use a block of wood, cut out to fit in the jack pad, or a folded up large wash cloth, both work well. Thanks for your input....
