where is crankshaft position sensor located?
Old 11-20-2017, 04:05 AM
winkawak
winkawak's Avatar
Default where is crankshaft position sensor located?
on a 2013 gt
winkawak is offline
Old 12-04-2017, 08:30 AM
Buck Sergeant
Buck Sergeant's Avatar
Default crankshaft position sensor located
winkawak, It's the black connector in the "passenger side" of the timing cover. A inch or so from the bottom edge. It's the only part on the timing cover in the lower left corner with any wires.
Buck Sergeant is offline
Old 12-04-2017, 09:02 AM
Buck Sergeant
winkawak, Sorry for that last post. Those directions are for older mustangs. Thy this,on passenger side, follow the O2 sensor wire, it is right below the connection for the O2 sensor.
Find the electrical connector and gently pull while pushing in the tab.
It is an 8 mm bolt that holds it in.
It is mounted on the bellhousing flange going through a hole.
Getting back in is tricky as it is magnetic and tends to want to go up near the flywheel/flex plate.
Old 12-04-2017, 09:14 AM
Buck Sergeant
Default where is the crankshaft position sensor located
winkawak, here is some additional info that might make it easier to find that sensor. The blue wire is the o2 sensor and if you look below it you'll see a wire with aluminum tape around it, that is the crank sensor wire. You can see the 8mm bolt next to it. It should stay in the sensor.
Old 12-05-2017, 10:44 AM
winkawak
winkawak's Avatar
thank you, much appreciated
winkawak is offline
StreetGhost
10-02-2016 11:28 PM
TheDivaDanielle
07-14-2014 07:40 AM
Hellbound
04-15-2014 03:33 PM
Turbo1014
08-21-2013 04:21 PM
Jarrod@latemodel
LatemodelRestoration.com
03-23-2012 04:25 PM
Quick Reply: where is crankshaft position sensor located?
