Grinding noise coming from engine bay?
So I have a 2007 Mustang V6, its an auto with 130k miles on it. I've had this really weird grinding sound coming from the engine bay. Happens during cold starts mostly. Once the engine warms up it goes away for the most part. I can only hear it again if I rev the car hard then it becomes extremely high pitched whirring sound.
Heres a video of it
This is a cold start
So far I replaced, belt, belt tension-er, idle pulley, and steering pump.
Thats all I've done so far. I'm at a loss here. Thanks for any kind of insight if ya have any! I think it may be the alternator if nothing else?
Heres a video of it
Oh another note, I have taken the belt off and started the engine on its own. The grinding noise is still there so its definitely none of the components it seems. So ignore the alternator part woops! Someone in another thread on reddit said that it might be the oil pump failing? My car is the super base model so I dont even have an oil gauge. I'm most likely going to go get one though today to test it out. Cheers!
Doubt very much it is coming from the oil pump. Check the harmonic balancer. It is the the part of the bottom drive pulley on the crankshaft. It is made up of two pieces the outer ring can move due to age,see if the outer ring moved back it maybe rubbing on the engine.
Ok so I went and checked on that and it seems to be in really good shape actually. May have been replaced by the last owner, I'm not sure. But here it is. I also recorded more video. The noise sounds like its coming from the back of the engine on the passenger side. Maybe its a timing chain? Though I've heard those almost never fail, unlike a belt. Heres the link to the playlist of videos: Playlist
Well you already know the timing chain is behind the left rear cylinder head. I have done a lot of timing chains in my day,but never on the mustang and I would hate to because any servicing the engine has to come out. "Ford has a better idea" I think they need to pull their head out of their ***.
