Battery drained
Some models, Mustang I dunno, but my '04 Explorer uses the PCM to "time-out" after shutdown, any lights left on, like interior courtesy lights, so if you leave a door ajar overnight it won't drain the battery.
Found the cause: broken trunk lock. Did not held the lid down. So, the small trunk light was on for a few days. Later, I saw also "Ajar" light on instrument panel when ignition key inserted, though all doors were closed..
I tought the battery was done, but I connected an electronic battery tester to it and diagnosed: "Battery good, charge it". I charged overnight and tested again, battery regained full capacity. So tester paid for itself already.
Yes, I checked the parasitic current drain after removing the bulb and it was just 22mA (0.022A) so it should be normal. The timeout is working on the courtesy lights but not on the trunk light, unfortunately.
I went to start mine this morning and no dice. I know if I don't drive it at least once a week it may not start. Since the weather is so cold I'm sure that has a lot to do with battery drainage. However, it is parked in the garage that is heated to around 45-50 degrees. I need to buy a battery tender for it. Any recommendations?
I have read that Trickle Chargers are bad for the battery. I ordered a Battery Tender Plus from Amazon. Many stang owners use it.
Whoever said Trickle Chargers are "bad" for a battery is full of hocum. So long as the "trickle" is more than the parasitic drain due to Air Bag Power Supplies, Keep Alive Memories, etc., the battery will always be ready to go.
It has been unseasonably cold for us and my stang was parked for a few days, went to start, it was a no go at first but it ended up starting. I have read that the cd or radio comes on by itself and hence dead battery, so I have removed the radio fuse and will test tomorrow since it has been a few days. Was told battery was good. If not might be battery drain from something else.
