Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
3.7 cyclone to 5.0 coyote swap
Old 01-21-2018, 04:00 PM
SlapChop1
SlapChop1's Avatar
Default 3.7 cyclone to 5.0 coyote swap
Hey all,
So long story short, I've decided after a long time that I want to swap my current 2015 mustang 3.7 V6 cyclone with a 5.0 V8 coyote engine.
I know that its going to cost a lot more then selling the car and buying another GT, but I simply cannot do so as its financed and im not looking to trade it in.
Money is not really an issue, I already have a few contacts including AmericanMuscle who sell the crate factory engines including the 5.0's.
What else is needed besides the engine itself? Will everything from the engine to the rear end of the car need to be replaced?
I just want to make sure I know what im jumping into before I get going on this project...
Any help is appreciated from you mustang guys, thanks!
SlapChop1 is offline
Old 01-21-2018, 05:49 PM
JimC's Avatar
Rear end is the same, no swap there.
You will need a PCM/ECU and transmission and probably a drive shaft. Others will be able to chime in with what else you need.
JimC is offline
Old 01-21-2018, 09:53 PM
proeagles
proeagles's Avatar
You are looking at about $9K in parts if you are going crate motor and PCM. Trade it and buy a GT, you will come out ahead in the long run unless you are really upside down on your car loan.
proeagles is offline
Old 01-22-2018, 01:14 PM
Crate motor, engine harness, PCM/ECM.
Not sure why a different tranny as JimC mentioned? Mustangs of the same generation use the same transmission regardless of engine (V6 or V8), except for in certain instances of a GT500.
Old 01-22-2018, 05:28 PM
JimC's Avatar
Because there is a difference in the bell housing - same transmission but different mounting and on the S197 models it also had a different input shaft (not sure about the S550 on that part)
JimC is offline
Old 01-22-2018, 11:17 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
This is a wonderful idea, I can't wait to see how it turns out.
redass02gt is offline
JIM5.0
5.0L V8 Technical Discussions
02-19-2013 07:47 PM
HareBrained
12-26-2010 02:36 PM
amhsraptor
04-27-2007 12:34 AM
mach1eleanor
03-14-2006 10:54 AM
mach1eleanor
Classic Mustang Classifieds
03-14-2006 10:51 AM
Quick Reply: 3.7 cyclone to 5.0 coyote swap
