Gilmer belt drive kits 5.0 1993 GT
Old 01-22-2018, 09:07 PM
Kidcruz
Kidcruz's Avatar
Default Gilmer belt drive kits 5.0 1993 GT
i saw someone post a video with the belt drive kit and it sounded awesome, but does anyone know if they make a kit for the 5.0 1993 mustang ? An does it make a difference power wise ?
Kidcruz is offline
Old 01-23-2018, 08:16 AM
Buck Sergeant
Buck Sergeant's Avatar
Kidcruz, Pros
- No slippage
- Low chance of throwing belts
- Noisy supercharger sound
Cons
- Cant get belts as easily if you throw them or strip teeth
- Not easy to setup for full set of accessories (alt/ps/wp/ac)
- Noisy supercharger sound with no supercharger
My crew chief suggests you do not overtighten the belt. The gear hub will eat-up the belt.
Buck Sergeant is offline
Old 01-24-2018, 10:49 AM
Kidcruz
Kidcruz's Avatar
Originally Posted by Buck Sergeant
Kidcruz, Pros
- No slippage
Cons
Do they sell a kit to run with the steering pump ?
Kidcruz is offline
Old 01-24-2018, 01:05 PM
Buck Sergeant
Kidcruz, READ EVERY LINE VERY CAREFULLY.
PROFLOW PFE STEALTH BLACK GILMER BELT DRIVE KIT
SUIT FORD V8 WINDSOR 289 302 351 & CLEVELAND 302 351 400
The Proflow Gilmer belt drive kits come complete with crank, water pump and alternator pulleys. Included with the kits are stainless bolts and a high quality Proflow belt. Made from machined alloy to precision specifications and available to suit most engine applications.
Get that distinctive gilmer belt drive sound for your beast!
Proflow Stealth Black Gilmer Belt Drive kit
Suitable for street and strip applications
Pulleys are fabricated from billet machined 6061-T6 alloy
Strong anodized for hardness and maximum life of your gilmer pulley teeth preventing slipping and wrecked belts
1 x Crank pulley, 1 x Alternator pulley, 1 x Water pump pulley
Supplied complete with 4 x stainless steel crank pulley bolts
Will suit 3 & 4 bolt cranks
1 x Proflow PFEGK 390L150 1.5" wide belt
Proflow gilmer belts are designed with extra nylon webbing making them thick for superior performance and durability
Crank pulley features a V belt groove which you may utilise to drive a power steering or air conditioning belt
100% billet construction, beware of cheap copies
Stealth black anodized finish (also available in polished, please see other listings)
12 month warranty
Genuine Proflow or your money back!
We carry the full Proflow range! Please see our ebay store for further products or contact us for further info.
Fitment notes:
Will not suit late EFI type or late model Windsor with serpentine style drive belt layout.
Gilmer belt drive kit will not drive air con or power steering accessories, crank pulley does feature V groove which can be used for this purpose
Belt supplied with kit 390L150 - if your engine has been altered over the years and you require a different belt length, please contact us before ordering
CarrieS
12-11-2014 12:25 PM
DEMONIC1589
09-14-2014 10:58 PM
SalikDDD
01-16-2008 02:14 AM
mAnYsTyLeS
08-29-2006 09:39 PM
Mig
04-15-2006 01:14 PM
Quick Reply: Gilmer belt drive kits 5.0 1993 GT
