2016 GT/CS Hood Paint Bubbling and Peeling Issue
I recently noticed that the front of my hood is bubbling up on both sides of my hood and has started to peel on the driver side. My car is still covered by the Bumper to Bumper warranty but I am wondering if Ford will fix the issue. I've seem some varying opinions on if Ford will cover it under the warranty as I don't know if its currently would be considered "perforated due to corrosion" as the warranty states is required and as others have said Ford used to deny coverage. I've also seen that this a common problem on some of the older models but I haven't found anyone else with a 2015+ with this problem. I have attached pictures of the two areas of concern.
Any and all advice would be helpful. I plan to take it to my dealership but want to do as much research as I can before hand as I fear an uphill battle getting this fixed by Ford.
All the advice in the world isn't going to solve this problem until you take it to your Ford dealer and see what they will do. Chances are if you have a good relationship with them, they will take care of you.
Originally Posted by redass02gt
They sure as hell should fix that. There is warranty against defects in paint, just not for wear and tear.
(depends on the dealer too,)
but they aren't covering it, most of the time.
(apparently, its because of the way the paint sticks to the metal, & the paint coats are too thin)
my 2006 is actually better than a 2018. theres not a flaw in any of my paint, & just wash it with rags & water & dry it.
The paint to aluminum adhesion issue has been around for a long time, Expeditions going back to 2003 and up through current models have it on the tailgates and hoods. I have had 5 Expeditions and all but one have had it, currently still own two of those and they both have it. The 2012 was fixed under warranty, and has it again. The 2010 has it, and in both cases they will not entertain fixing either. My 2016 Mustang has it, and is going into the shop to have a new hood put on. If it is any indication how many of these they are doing, the hood was on back order.
