Torque converter question
AOD trans is from a 90 gt 5.0. After removal I noticed these marks on the t/converter from the flexplate mtg bolts. They're not that deep but I'm concerned about it b/c I've never seen this before. Should I be, maybe add shims between the flexplate to t/converter mtg studs? Thanks in advance. Also how do I resize my uploaded photos from my Droid tablet.
The converter bolts directly to the flexplate, so the converter does "spin" with the engine, but not against it. So it won't grind.
I don't know much about torque converters, but I don't think it's supposed to contact the flexplate-to-crankshaft bolts like that. That's what that recess in the TC is for, isn't it? I wonder if this might be indicative of what they call "ballooning":
Puddle lights?
sewerrat, I like your handle. That picture paints a very scary scenario. Please check the part numbers to make sure you have the correct torque converter and flex plate combination. I would not do any shimming back there unless you wear steel shoes. The flex plate is equal to a buzz saw and will eat you up. I saw, at a national event, what not having the right converter and flexplate combination will do to the human body. Also, I would suggest using ARP hardware on the converter and flexplate. The AOD in OEM form is a big piece of crap to begin with. And before the boys jump into my socks, yes, after being highly modified/upgraded they will behave pretty well. I will take a C-4 any day of the week over a AOD.
I bought this 90 gt for $300 for the 5.0 and drive train to transplant into my 84 v6. I've already rebuilt and swapped in the 8.8 and took the larger sway bars. the body is shot and and will be going to the scrap metal yard soon. the owner drove it to my house and said as far as he knows everything is original. I"ll see if I can find the ford stamping to verify if its OEM. I've taken off many trans from engines before both import and domestic and never saw this before so I wanted your opinion. the vehicle odometer stated 27K so I'm guessing 227K.
Problem Was Described In A TSB # 92-18-6
I was just browsing thru some American Muscle tech and noticed they had some TSB's listed,so I looked thru them.It turns out,your problem seems to be talked about in one of those bulletins.Numerous models were listed,including the 82-90 AOD Mustangs.It stated,the torque converter flexed enough to create contact between the tc and flexplate bolts.A part number was listed for new flexplate bolts with a reduced head height.The TSB number is 92-18-6 and the part number for the bolts is F1ZZ-6379-A.
The app I use to view pdf's wont let me copy/paste a pdf or share it other than by email,so if you wanna download the 2 page pdf for this TSB,click the link below,scroll down to the ( Foxbody Mustang Technical Service Bulletins ) section,locate the 92-18-6 link in blue and click it to download the pdf.
https://www.americanmuscle.com/foxbo...nfo-specs.html
I figured out how to share the pdfs with my gallery,so just in case another member or guest runs into this same issue,the pdfs are shown in image form below (to prevent anyone from having to go search for them seperately.
