Vehicle Died While Driving! Help!
Old 04-04-2018, 12:36 PM
06LegendLimev6
06LegendLimev6's Avatar
Default Vehicle Died While Driving! Help!
Hello everyone, I have a 2006 v6 automatic Mustang. I was driving this morning and all seemed fine. I went to push the accelerator pedal and nothing happened. The rpms stayed at 1000 as I was coasting at about 40 mph. I kept pushing the pedal in vain. Nothing happened. So I put the car in nuetral because I was on a curvy road and wanted to find a good place to pull over. When I did so, the engine cut off, with it I lost power steering and power brakes. While I was coasting only the check engine light illuminated. When I came to a stop I put the car into park and shuffled through the owners manual. I then proceeded to try anything to get it to start back up. I clicked the Fuel reset switch and it still wouldn’t continue running. It would fire up, run for maybe a second or two and shut off. After I had sat there for about an hour checking everything I could I went to crank it again. Miraculously the engine fired up and the check engine light was gone. After I made it home I checked/cleaned the MAFS. It was already clean but I figured it wouldn’t hurt. Now the car fires up again and again without any signs of anything wrong. Beats me! I was wondering if any of you guys had similar problems or know someone who has. I am really worried about this car! I have ordered a SCT/X4 and it is supposed to arrive tomorrow along with my tunes. I will use the scan feature on it to see if I can any P### codes. Thanks in advance!
06LegendLimev6 is offline
Old 04-05-2018, 01:04 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Sounds like either the throttle position sensor or the accelerator pedal position sensor is at fault. The former is more likely as it's more vulnerable to heat soak related failure.
Scan your ECU for fault codes.
Dino Dino Bambino is offline
Old 04-05-2018, 06:53 AM
ZEN357
ZEN357's Avatar
Take it to the dealership. Don't take any chances driving it.
ZEN357 is offline
Old 04-08-2018, 05:34 PM
06LegendLimev6
Just wanted to update everyone. I have since drove the car nearly 600 miles with no issues. I drove down the beach and back this weekend. Ran like a top. Thanks for your input!
Old 04-09-2018, 03:00 AM
Dino Dino Bambino
If the engine died once, it'll die again and it'll do it more frequently. Get your ECU scanned for fault codes 'cause the problem won't have suddenly cured itself.
Old 04-09-2018, 09:12 AM
06LegendLimev6
Inhave scanned and no codes where shown. If the issue comes back I will have my scanner to find out what is wrong.
Old 04-24-2018, 01:21 PM
Throttle plate on the throttle body got stuck closed maybe or loss of signal between the gas pedal and PCM as already mentioned.
Definitely check into it. You got lucky this time that you were able to coast to a safer area. Next time you might be stopped to turn left in the middle of the intersection with oncoming traffic.
Old 04-24-2018, 05:06 PM
algregory
algregory's Avatar
I've been seeing advertised a Code Reader that "speaks/prints" to your cell phone with code information. Seems to me it was supposed to give a more detailed output instead of just a number or what have you. Anyone tried it? Bought one?
algregory is offline
Old 04-24-2018, 05:19 PM
06LegendLimev6
I know American Muscle offers a LiveWire ITCS (don’t hold me to the exact name, lol) but the LiveWire is supposed to use BluTooth to download tunes onto your car as well as serve as a gauge layout. The app even includes 0-60 time/speed and an estimated Hp/Tq outputs.
I also saw a video ChrisFix made on YouTube where he uses a Bluetooth scanner tool that connects to your phone.
Personally I have a SCT X4 with Bama Custom tune. (Of which I am actually having trouble with.) As far as the SCT X4 goes, I love it. I also purchased the windshield mount and love being able to watch all the temps/ readings.
mtoliverjr
09-28-2009 10:59 PM
BAY68_347
08-03-2009 08:15 PM
88 347 stroker
04-20-2009 08:35 PM
sharkysgt
11-15-2008 09:27 PM
Braydon619
07-08-2007 08:41 PM
Quick Reply: Vehicle Died While Driving! Help!
