Dark valve rocker
Not enough oil. The little oil it's getting is baking under the heat, and leaving all that
carbon build up. Can't tell from the picture if the push-rod is also dark and carboned
up, because the far left one looks dark in the picture as well.
There is puddled oil in there, it's just darker, and not as much as the others.
Either, it is an oil delivery issue, or that one is running hotter than the other ones,
but that can also be due to lower oil flow there. If that cylinder is running lean,
that exhaust valve can run hotter.
AZAlloy
03-18-2008 03:23 PM
fablefifty
12-29-2006 10:32 PM
RxRot
06-10-2005 07:20 PM
