Excessive brake dust
Old 05-22-2018, 11:26 AM
Tanya Luciano Woods
Tanya Luciano Woods's Avatar
Default Excessive brake dust
So I just got the Calipers, Rotors and pads replace 2 months ago on my 2004 GT Convertible. Before the replacement we had excessive dust on the front 2 wheels. I assumed that with the parts that this would resolve. But its still pretty bad. I've been letting my 17 year old drive her mostly. Could it be she is just too heavy on the brakes? THX
Tanya Luciano Woods is offline
Old 05-22-2018, 01:24 PM
It could be they ride the brakes or it could be the type/brand of brake pads you went with. What brand did you go with and what type were they? I only use Ceramic type brake pads from Akebono which have little dust and excellent braking power.
Old 05-22-2018, 01:34 PM
Tanya Luciano Woods
I don't know. I just took the car to the dealership. I'll find out and look into ceramic pads. THX
Old 05-23-2018, 03:22 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
i daily drive a X3, the OEM pads would leave the wheels black after 100 miles. switched to akebono ceramics from napa and i havent had to clean the wheels since
WhiteFoxGT is offline
Old 05-23-2018, 04:38 PM
08'MustangDude
08'MustangDude's Avatar
Yeah, brake dust depends on the quality of the pad, and type. Depends how dense the
pad material is, what it's made of, and what else is in the material.
The more "metallic" the pads are, the worse it is. The steel fiber content in pads
can be up to 30%. The fibers are abrasive, that is what scratches your brake rotor
and that causes the dust. SO, yeah, the brake dust that we all see on our rims is
92% iron. Simply put is in caused by abrasion of the cast iron brake rotor by the pad,
and secondly the fibers from the semi metallic elements of the brake pad.
Pads that are made with Twaron or kevlar fiber are only (usually) available as upgrades.
The reason manufacturers opt NOT to use these more expensive pads, is simply for build
cost purposes. These pads last longer too, are less abrasive against the rotor, thus less
brake dust.
08'MustangDude is offline
Old 05-23-2018, 05:40 PM
WJL
WJL's Avatar
https://ebcbrakes.com/articles/brake...hat-causes-it/
WJL is offline
Old 05-23-2018, 07:39 PM
TheBabyBadger
TheBabyBadger's Avatar
The 17 year old probably hits the brakes later and harder than you, too. Sometimes that can accelerate it. Or they used some A/M pads and rotors. If it went to the dealer, I doubt that though. Good luck! Wash her more!
TheBabyBadger is offline
ChesterKaup
10-05-2009 03:26 PM
72MachOne99GT
05-16-2009 09:40 AM
ChesterKaup
02-27-2009 02:28 PM
Stangatic
01-18-2008 07:58 PM
VaderGT
04-03-2006 06:25 PM
Quick Reply: Excessive brake dust
