What caused this on piston. Pictures attached.
Old 06-15-2018, 09:38 AM
wmrcer
wmrcer's Avatar
Default What caused this on piston. Pictures attached.
Pull the heads off and this is what I found on one of the Pistons. Picture of valves on head are for that cylinder.
wmrcer is offline
Old 06-15-2018, 04:35 PM
Coosawjack
Coosawjack's Avatar
Water!!
Coosawjack is offline
Old 06-15-2018, 04:40 PM
jmarks99
jmarks99's Avatar
most likely a cracked block.
jmarks99 is offline
Old 06-15-2018, 04:42 PM
08'MustangDude
08'MustangDude's Avatar
Looks like coolant, with some kind of block seal additive. People add that stuff
to the coolant so stop head gasket leaks and such. Sometimes it works,
sometimes is does not. When it does work, it's not permanent either.
08'MustangDude is offline
Old 06-15-2018, 04:44 PM
jmarks99
jmarks99's Avatar
didn't see any tell tale sign of failed gasket. usually leaves a visible pathway from a water jacket port to the cylinder.
jmarks99 is offline
Old 06-15-2018, 04:47 PM
jmarks99
jmarks99's Avatar
but do need to see underneath the gasket on block to tell for sure.
jmarks99 is offline
Old 06-17-2018, 02:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
moisture/water......what issue were you having?? overheating.....coolant loss?? what was the reason for disassembly?
mjr46 is offline
Old 06-21-2018, 04:30 PM
eggsmith
eggsmith's Avatar
How long has it sat before pulling heads?
eggsmith is offline
N3mi5is
12-31-2011 03:31 PM
Furinox
Mach 1 Section
08-05-2008 06:44 PM
dukeme
02-03-2008 09:32 PM
Shelty
01-10-2008 12:03 AM
86GT 93LX
09-26-2007 02:10 AM
Quick Reply: What caused this on piston. Pictures attached.
