Trans fluid
Old 06-16-2018, 05:20 PM
Simonsaygofast
Simonsaygofast's Avatar
Default Trans fluid
Hi Im importing a V6 auto, 2006 standard model, do I need an additive when I change the trans fiuld? Some Chrysler models require an additive when you drop the pan, just wondering if it's the same for Mustang thanks .
Simonsaygofast is offline
Old 06-17-2018, 03:38 AM
08'MustangDude
08'MustangDude's Avatar
I am not sure what it is, but when I had ford change the fluid in mine, one
of the line items just said "Transmission service and Conditioner." So, do not
know what the conditioner is. Normally, nothing else but trans fluid goes
in.
08'MustangDude is offline
Old 06-19-2018, 02:01 PM
a 2006 auto transmission 5r55s uses standard Mercon V fluid. That's it, no other conditioners or additives needed.
That being said, it's been said (mainly by the mfg of the additive I'm about to mention) that you can add this stuff for additional protection and it's supposedly endorsed by many car mfg's. Don't know about Ford specifically but Honda, Acura etc.
http://www.lubegard.com/~/C-112/LUBE...uid+Protectant
http://www.lubegard.com/pdfs/HeatChart%28AL-516%29.pdf
I'm not one to recommend additives for the sake of recommending them. Transmission fluid has a finite life and adding something will not change that. If it did, OEM's would be all over it and sell it to you direct.
If you want to extend the life of the 5r55s two things. Improve the cooling by getting a secondary tranny cooler and replace the fluid at regular intervals (30-40K miles). The addtional tranny cooler is probably not a big issue since you are in england but here in Arizona...it's a must.
Old 06-19-2018, 04:24 PM
08'MustangDude
Usually, you add a medium duty trans cooler, AFTER the radiator, if this is how it's set up.
Trans fluid to the rad, out of the rad, into the cooler, out of the cooler, to the trans. My '08 has
a separate cooler, it does not go through the rad first. It is not very efficient, because the
temperatures fluctuate from idle to moving. My '07 Charger was the same way, but it had a
larger cooler.
So, now, you have to go from the factory cooler, to the secondary which you will want in FRONT
of the condenser. It would be nice to put it down at the lower grille opening, so you can add
a cooling fan behind it, using a thermo switch kit. This way, you can keep the trans temps
down to ~170 - ~180 degrees. Or, buy a rad with trans cooler connections, reroute there first, then
to the factory cooler.
Old 06-20-2018, 07:37 AM
outceltj
outceltj's Avatar
Id suggest getting a larger transmission pan. You would be able to check your fluid as well with the extra capacity
outceltj is offline
Old 06-20-2018, 01:05 PM
08'MustangDude
The PML Deep pan was discontinued, and this one had cooling fins.
Trick Flow sells them, $300+, with a new dip-stick tube and dip-stick.
Can check eBay, Amazon...
turbo232
08-06-2011 03:58 PM
mstngsule68
06-16-2010 11:08 AM
88BlueGT
10-01-2007 09:04 PM
ChrisZio04GT
05-01-2007 12:52 AM
Tims 88GT
04-29-2005 11:08 PM
Quick Reply: Trans fluid
