Advancetrac light and and airbag light come on the go off
Checked wheel speed sensors and fuses, vehicle was tuned but pcm was tuned on the bench not in the car. My tuner says the modules need to be remirrored with the pcm I tried the battery reset for like a hour.. battery died during tune loading that's why we put it on the bench. Vehicle runs great is there a way to do this without going to the dealer and if so what would be the cost to remirror to the pcm. Should only take a hour to do I've done this with other makes I was a Mercedes and BMW master tech among a rotary tech at Mazda. Just wondering other people's thoughts and if they have seen this before thanks for the input!! Car is a 2015 Roushcharged GTPP. VMP triple pass heat exchanger and custom coilovers problem wasn't there before tune so input PLEASE!! Thanks
[QUOTE=R2300S550;8628190]Checked wheel speed sensors and fuses, vehicle was tuned but pcm was tuned on the bench not in the car. My tuner says the modules need to be remirrored with the pcm I tried the battery reset for like a hour.. battery died during tune loading that's why we put it on the bench. Vehicle runs great is there a way to do this without going to the dealer and if so what would be the cost to remirror to the pcm. Should only take a hour to do I've done this with other makes I was a Mercedes and BMW master tech among a rotary tech at Mazda. Just wondering other people's thoughts and if they have seen this before thanks for the input!! Car is a 2015 Roushcharged GTPP. VMP triple pass heat exchanger and custom coilovers problem wasn't there before tune so input PLEASE!! Thanks[/QUOTE
I have had my modules remirrored and No I didn't have to have the car set back to the factory calibration like Ford said... my tuner Matt of ID MOTORSPORTS remirrored the Advancetrac although the ABS light did come back on we pulled the codes and there were 4 for the rear right and sensor. I pulled the sensor out shined a light in the hub through the ABS sensor hole and found some string black rubbery material I got what I thought was all of it out does anyone know what this could be maybe the back of the bearing that plastic maybe shredding apart just wondering if anyone has seen this. Weird issue
pat60527
07-29-2008 05:29 PM
