tranmission noises
Old 08-13-2018, 10:12 PM
jasons03gt
jasons03gt's Avatar
Default tranmission noises
hey guys i have a question that concerns the tr3650 5 speed
when i press the clutch in im hearing alot of different noises scraping scratching squeaking and when i let off it goes away, if im driving and press it in to shift it groans loudly like a power steering whine and when you release it, it stops. my question is would it be a throw out bearing or pilot bearing? or input shaft? when you let off the clutch it pull out it chatters badly it feels and sounds like a machine gun under your feet!! it gets worse the longer you drive it.
jasons03gt is offline
Old 08-14-2018, 01:27 PM
How many miles on the existing clutch? You definitely need a throw-out bearing but, depending on the age, you will want a whole new clutch kit anyways.
The chatter is the either the clutch disc springs worn/broken and/or the clutch plate springs worn/broken. There's an inspection plate under the bell housing held on by a screw/bolt, remove it and take a look at the condition of everything. If you replace one part, may as well replace them all, Throwout bearing, pilot bearing, disc, and plate.
Old 08-17-2018, 07:49 AM
jasons03gt
jasons03gt's Avatar
there roughly 214k miles on the car. i owned it since new 4 miles when i bought her and i never had the clutch replaced, i didnt start having these noises til about 2 weeks ago or so i was almost worried that it was the gears but then it dawned on me it only happens when i disengage the clutch. thanks for the advice!!
Old 08-17-2018, 01:44 PM
Z28KLR
Z28KLR's Avatar
214K on a factory clutch is a pretty good run. Time for some new stuff.
Z28KLR is offline
Jdcrem00
07-16-2018 05:47 PM
91bigredgt
07-16-2007 04:06 PM
nacanitihs
07-01-2007 03:35 PM
ngirg001
04-09-2006 10:00 PM
289_CaSpEr_302
03-07-2005 10:43 PM
Quick Reply: tranmission noises
