Po305
Old 08-17-2018, 05:59 PM
jriner1994@gmail.com
jriner1994@gmail.com's Avatar
Default Po305
PO305 cylinder 5 misfire. Okay so I pulled the plug and it had water on it I sprayed it out, did pressure test found no leaks around intake... I cut the code off and am going to see if it comes back on if it does and doesn't have water I'm going to replace spark plug. If it does have water im going to have to replace intake manifold? Suggestions, help!
jriner1994@gmail.com is offline
Old 08-17-2018, 08:15 PM
08'MustangDude
08'MustangDude's Avatar
Switch coil packs with another plug, see if the code moves to the
other cylinder.
08'MustangDude is offline
Old 08-17-2018, 10:12 PM
The code hasn't came back yet. Idk where the water came from.. I know if you switch to another and it does it it's probably the plug wire. I'm going to wait a week while monitoring codes and see if it comes back. If it does and doesn't have water im change plugs and wires.
Old 08-18-2018, 11:57 AM
sweetbeats
sweetbeats's Avatar
Just verify, cylinder #5 is the one on the driver’s side bank closest to the front of the car? Does your car have the original manifold with the plastic coolant crossover pipe? And what MustangDude said...if the code comes back and the spark plug well is dry, swap the coil pack with another cylinder, clear codes and see if the code comes back but on the cylinder to which you swapped the pack. If that’s what happens you need a new coil pack. It’s not likely a problem with the spark plug.
sweetbeats is offline
Old 08-18-2018, 02:25 PM
Yes and yes it's the original intake which I know they are famous for leaking because of the plastic coolant cross over. And the coil pack isn't but probably 3 months old I change it out when I got the car because the end connector was broken where it plugs. But I mean it could of crapped out, I'll try what y'all said if code pops back up.
Old 08-18-2018, 03:09 PM
Z28KLR
Z28KLR's Avatar
If you had coolant in the plug well then that's your problem. No sense spending time moving coils around or anything else until you figure out why there was coolant there and make it stop (which I can assure you will not do on its own).
Probably time for a new manifold and gasket set. What year is your car, since you have the all plastic manifold then I assume 2001 or earlier? When you get the updated manifold you will also need an alternator bracket to go with, as that was also changed slightly. Not very expensive, adds like $15 to your parts bill.
Z28KLR is offline
Old 08-18-2018, 05:02 PM
98, and it's just weird though I did pressure test and couldn't find a leak anywhere. I just didn't want it to be the intake.. doesn't seem to hard of a job tho.
Old 08-18-2018, 05:06 PM
Haven't been losing coolant either and hasn't been running hot. But like I tell people it'll get worse before it gets better. I'm check the plug for water again this weekend. Might just go ahead and replace intake heard the factory ones are famous for leaking.
Old 08-18-2018, 05:26 PM
sweetbeats
sweetbeats's Avatar
The leaking doesn’t happen all the time and you can’t really diagnose with a pressure test IMO. It seeps. And it doesn’t take much to fill the plug well. Like Z28KLR said, if it’s coolant in the plug well, dollars to doughnuts it’s a failed coolant crossover and the manifold needs replaced. So that’s really step one is to verify it’s coolant...and it probably is...unless somebody is pouring water in there while you sleep.
Old 08-18-2018, 05:34 PM
Haha 😂 damn neighbors... but I found what I need. Comes with alternator bracket, thermostat everything and it's on sale! Thanks so much guys! I'm new to this and y'all have been a great help! https://www.carparts.com/details/Ford/Mustang/Replacement/Intake_Manifold/1998/GT/REPL311902.html?TID=gglpla&origin=pla&gclid=EAIaIQ obChMIkdOP8If13AIVhpOzCh1pew98EAQYAiABEgILy_D_BwE& gclsrc=aw.ds
Quick Reply: Po305
