New Rear Shocks Installed
Old 08-24-2018, 05:02 PM
08'MustangDude
08'MustangDude's Avatar
Default New Rear Shocks Installed
Just providing some pictures.
Some info: The new shocks upper mounts were larger in diameter, and use
larger nuts. The nuts are separate from the upper mount dome, and are 15mm
-vs- 13mm OE nut.
The bottom shock bushings are larger on the new ones.
This was EASY, and so where the LCA installs. Ford using those nuts with the
built in stops is a life saver!
08'MustangDude is offline
Old 08-26-2018, 11:34 AM
07 Stang
07 Stang's Avatar
Is the ride noticeably smoother?
07 Stang is offline
Old 08-26-2018, 02:34 PM
08'MustangDude
Yes, much better, and of course no mire sliding out when hitting bumps on turns.
Looking for an upper LCA and Panhard bar.
Old 09-22-2018, 07:38 PM
sp44
sp44's Avatar
What brand are the new ones?
sp44 is offline
Old 09-22-2018, 08:11 PM
08'MustangDude
They were supposed to be AST, but the label said "Maxorber". I contacted
the people and said, the picture shows AST shocks, and I got these (attached
pictures), and they sent a partial refund. They still work great, and were only
$24.39, and I got $7.00 back. They are now relisted for $38.36, and still
show AST in the pictures. They claim the ones I got are made by the same
company that makes the AST shocks.
https://www.ebay.com/itm/Rear-Set-Le...6/262795808213
Old 09-25-2018, 07:10 AM
Norm Peterson
Norm Peterson's Avatar
Yes, those flag nuts sure do make life easier . . . most of the time.
The ones up front for the strut to knuckle fasteners aren't quite strong enough, though. They will bend over if you don't grab the nut with another socket on a breaker bar.
Norm
Norm Peterson is offline
Old 09-25-2018, 03:46 PM
08'MustangDude
They will do that if the threads are rusted, that is where the resistance is.
Clean threads, that would not happen, no matter how tight the bolt is, as
long as the threads are clean, it won't put more torque on the flag nuts.
All mine came out easy, and the flag nut came loose as soon as the
bolts were loosened. When I got it, the oxidation was not that bad, but it
sits outside...
iceguyb14
12
05-09-2012 10:11 AM
Jeffk
04-06-2012 10:40 AM
gearbanger
05-13-2010 08:01 PM
detailersdomain
10-02-2009 09:28 PM
Detroit Style
11-24-2008 06:52 PM
Quick Reply: New Rear Shocks Installed
