2005 convertible leak
Old 09-17-2018, 08:11 PM
whiterabit998
whiterabit998's Avatar
Location: vids> http://vids.myspace.com/index.cfm?fusea
Default 2005 convertible leak
And it's not from clogged drain plus in the firewall or in the rear wheel well. I've attached a video. It would appear near where the quarter window and top meet there is a member that water carries water over. I'd find it under the rear seats sloshing around and even in the area where the top rests when it's down. Any ideas? I have not found anything close to this all over the web. Everything I've found is about the water leak attributed to clogged drains. The kind that ruins the smart junction box and soaks the carpet.
Last edited by whiterabit998; 09-18-2018 at 10:52 AM. Reason: make the youtube link
whiterabit998 is offline
Old 09-18-2018, 09:02 AM
golfster
golfster's Avatar
I had the same problem with a 2007 convertible. Check that the extra material from the top in pushed into the gutter. You will have to take out your back seat and get up in there to see where the material ends. I took out the seat closed everything up and had a person spread the top with water to find it. Once I did it was an easy fix.
golfster is offline
Old 09-18-2018, 10:53 AM
whiterabit998
Thanks, I feel like it's that extra material that is feeding water over from the fender side (where water is supposed to drain down) to the cabin side.
mockwizard
V6 General Discussion
02-08-2017 08:27 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
bull49
06-06-2011 04:00 PM
IRSmart
Convertible Tech
04-15-2009 05:44 PM
Dan Alesandro
12-15-2006 01:20 PM
Quick Reply: 2005 convertible leak
