Electrical gremlins
Old 09-24-2018, 01:51 PM
zars50
zars50's Avatar
Default Electrical gremlins
A couple questions for you experts:
1 My rear backup light only work when in drive not reverse. Anyone have this fix?
2 Turn signals and drive lights work except front Right. It does work if switched to the left. All are upgraded to LED. Apply turn signal left fine, front and back. Apply signal right and rear works but front blinks on the left.
Any help would be appreciated since i'm not very electrically inclined.
Bret Taylor
1965 fastback
zars50 is offline
Old 09-25-2018, 10:34 AM
Stepman
Stepman's Avatar
What trans do you have? The lights sounds like a bad ground on the right front or something goofy in the switch.
Stepman is offline
Old 09-26-2018, 09:32 AM
zars50
zars50's Avatar
My trans is a regular C4 that was just rebuilt. I have also replaced the neutral safety switch as well.
I have checked and have a ground on the left front as well.
zars50 is offline
Old 09-28-2018, 08:58 AM
bop11
bop11's Avatar
The neutral switch has 4 leads.
one of the red and blue goes to the start position on the ignition switch, the other to the starter solenoid.
The One black and red goes to the fuse box the other to the backup lights. Possible that you could have the wiring messed up in this connector.
Switch
bop11 is offline
Old 10-06-2018, 12:20 PM
zars50
zars50's Avatar
Thx bop. I'll be able to check this next week.
Bret
zars50 is offline
Old 10-06-2018, 01:49 PM
Gun Jam
Gun Jam's Avatar
when upgrading to the LED did you switch to the digital flasher box (little round can thing under the dash) or are you still using the old bi-metalic flasher? Most LEDs dont produce enough current to run the old style flasher and can cause them to not operate proper.
Gun Jam is offline
Old 11-02-2018, 02:19 PM
zars50
zars50's Avatar
I did switch to the supplied LED flasher that I had received from my tail light upgrade.
Thanks
zars50 is offline
Dustin Deyagher
12-22-2016 11:27 AM
scootchu
08-14-2009 08:40 AM
jamieNerikas66stang
09-24-2008 08:22 AM
Alero99
04-26-2008 02:37 AM
3025L
03-20-2006 02:17 AM
Quick Reply: Electrical gremlins
