06 Mustang gt transmission
So a little less than a yr has gone by since my transmission stopped working right... been tryi g to figure out if I need to replace it or if it's a smaller fix. It's a 06 GT automatic. It's got use of 1st, 2nd, and 3rd gears but wont drive normal. Theres no reverse or drive?!?
Any suggestions/ advice?
Odd that it won't go into 1st in "D" but does if you put it in "1"? You said you have use of
1,2, and 3, but "D" starts in 1.
Reverse and 1st gear run off the same drum.
The low/reverse planetary gearset is connected to the reverse brake drum by lugs from the low/reverse brake drum to the lugs of the low/reverse planetary gearset.
The low/reverse planetary gearset is driven by the forward sun gear which is splined to the input shell.
The forward sun gear drives the pinions in the low/reverse planetary gearset.
The pinions of the low/reverse planetary gearset drive the output shaft ring gear and output shaft hub which is splined to the output shaft.
The low/reverse planetary gearset can be held by the low one-way clutch in the low/reverse brake drum, or by the low/reverse band.
REVERSE/LOW BAND:
REVERSE/LOW BAND:
REVERSE/LOW BAND:
REVERSE/LOW BAND:
https://www.valvebodypros.com/assets...ngagements.pdf
SO, basically in "D", he says, it's fully electronically controlled. When in selecting 1, and upshifting
manually, your bypassing the programming for manual control. However, it will upshift auotomatically
each time it hits the rev limiter.
So, yep, check the range sensor at the trans for a loose wire, bad connection, and so on.
Also, though, you should be able to go through 1,2,3, then "D" for 4th and over-drive. If it fails
as soon as you his "D" when manually shifting, then I would definitely check the range
sensor.
sensor.
Everything you said except the last part shifting at red line. This transmission will not up shift to the next gear it you have manually selected a gear. It will just bounce off the rev limiter and violently cut the fuel on/off once it hits redline.unless you manualyl raise the gear or put into drive.
Will try that... Every car I have owned, thus far, even if I put it into 1, will up-shift at the
rev limiter. My charger did it, my VWs did, my 2000 AVenger ES did... I have not really
RAN my Mustang to find out, but I will now... My VWs and the Charger had the auto-stick,
the +/- bump shifting, and still, when I leave them in 1, as soon as I hit the rev limit, they up-shifted.
My '15 TSI does it now. So, yeah, will see what my '08 does if I leave it in "1" and I will video
if it up-shifts anyway...
Oh, I'll save you the trouble, it won't. Done it many times accidently and it isn't graceful nor fun. It's 's cringe worthy. These arent like the 5r55e in the thunderbirds that had the manushift option and i believe will do that. (Upshift automatically at redline regardless of what gear you're in).
