Terminator 4v swap into s197 2005 ?
Guys, please help. If i install Cobra Terminator 4v into my s197 2005, PCM and wiring i will use from 2005 GT s197 or i have to buy wiring and pcm from Cobra 2003 ? And how it can compare with original cluster and other modules.
You will need the wire harness and control modules (PCM/ECM etc) from the donor car. You will also need to get custom engine and tranny mounts made. As for the speedo and and other guages, that will also be different and most likely custom or spliced in. The Cobra is an older generation so things will not be plug and play with 05+ systems.
Goals, budget and intended use for the car??
It can be done I'm sure, but there will be many electronics related hurdles and depending on your answer to the above question I'm sure there has to be an easier and more cost effective way to get you there. If looking for a swap to raise eyebrows when you pop the hood I'm sure this will put a check mark in that box. If you just want 400hp then there are easier and less expensive ways to do that than an overpriced 14 year old engine.
Nikita_str77
10-11-2018 01:00 PM
