self starting
Old 10-15-2018, 04:43 PM
tomtaras
tomtaras's Avatar
Default self starting
i have a 1966 mustang-302 engine-storing the car for the winter-i turned the car off with the key and the car started up again-pulled the negative battery cable-car shut off-reconnected the negative battery and restarted the car with the key-same problem and if fact i could restart the car with the key in accessory or start position-i am assuming a grounding problem-any ideas
tomtaras is offline
Old 10-16-2018, 02:10 PM
bop11
bop11's Avatar
Sounds like the ignition switch has gone bad.
bop11 is offline
Old 10-16-2018, 02:17 PM
bop11
bop11's Avatar
easy replacement.
bop11 is offline
Old 10-20-2018, 06:15 PM
barnett468
barnett468's Avatar
your engine was running with the key in the run position?
you turned the key off and the engine stopped?
a few seconds later the engine restarted itself but the starter solenoid did not stay engaged?
barnett468 is offline
michaeldoggrell
02-26-2011 10:05 AM
5OhToGo
07-30-2010 11:44 PM
1967coupeon101
06-14-2010 12:48 PM
jamieNerikas66stang
09-07-2008 12:46 PM
dgnret
11-10-2006 01:01 AM
Quick Reply: self starting
