How to remove quarter window vented covers
Old 10-23-2018, 06:29 PM
bodon
bodon's Avatar
Default How to remove quarter window vented covers
I have a 2014 GT. How do you remove the (stock) quarter window louvers ? I'd like to clean under them. Thanks
bodon is offline
Old 10-23-2018, 07:06 PM
08'MustangDude
08'MustangDude's Avatar
Fishing string, like cutting cheese... They're 3M taped on, so you should be able
to slice through that. Once you remove them, you need to adhere them back on,
they're not "removable" for service...
08'MustangDude is offline
Old 10-23-2018, 07:14 PM
JimC's Avatar
Are there stock, as in factory installed, quarter window louvers? I thought it was glass from the factory and any louvers were after market.
JimC is offline
Old 10-23-2018, 07:29 PM
08'MustangDude
You can order them for installation, done at the dealer. I would not say "factory" as in they rolled off
the assembly line with them, but dealer installed, one would assume factory... Or, when you send
it off to Roush or whoever, they install them with certain packages.
I don't think they roll out of the factory, with them on.
Old 10-24-2018, 01:40 PM
Yep and this would be what you use to stick them back on...
Amazon Amazon
Be sure to use some alcohol on both surfaces before bonding it back on. Ambient temps should be above 70F for best adhesion or you can use a hair dryer to warm up the surfaces.
Old 10-25-2018, 05:30 PM
bodon
bodon's Avatar
They came from Ford. Not after market. Thanks for everyones comments.
bodon is offline
kevinmalec
05-02-2011 11:09 AM
BlueBellThunder
02-27-2011 02:30 AM
Ms Stang
10-04-2007 09:59 AM
stanngg
09-22-2007 05:25 PM
Chanedeezy4106
02-09-2005 06:02 PM
Quick Reply: How to remove quarter window vented covers
