Wiring questions
Wiring questions
I need some help. I have a 2002 V6 coupe. The power lock and power mirror switches on the driver's door do not work. I checked the power pins on the switch plugs and they don't have power. The power lock switch on the passenger door work, so I know the fuse is good. Plus I visually checked the fuse. I've studied the wiring diagram. Power should be going to pin 11 on one of the plugs (C237) going to the door harness. I see the two harness bundles comIng from the door through the body, but they both turn up and go behind the GEM. How do I get to those plugs?
Gees, the service manual is now very helpful with thatvtype info. But I will look at both my manuals.
they spend so mch space showing a test meter and not exploded diagams that would help,locate parts.
i will get back soon.
