Both headlights work on low beam but only 1 works on high?
Is this likely a bad relay or a bad bulb since its only 1 side? Low beam on both sides work fine and the high beam on the left works fine. I had paintless dent removal done on the same side where the issue is, maybe they jarred it and blew the high beam or pulled on a headlight cable? Or bulb just failed?
