Auto shifter handle
Auto shifter handle
Couple questions. I have a new shifter handle. Do you have to remove the console to disconnect the overdrive wires? And, does the push button on the side just pull off? new one doesn't have one.
Thanks!
Thanks!
Yes, it all has to come apart, and unplug, then reverse for install...
The "T" handle is on with a TORX screw. When you remove it, the "T" handle will
pop upward, there is spring for the shift lock button (left)... Then it comes off as
ONE piece, but you unplug the O/D button (right) wires to remove completely.
You're saying it doesn't have, WHICH button? Without a picture, can't help...
The dust cover, blind, and PRND321 are part of the assembly, and it comes off.
There are tabs that hold that on, you can release them and pull the that off. I took
mine off to paint it.
This shows the "T" handle already off, but you can do it AFTER this bezel is off.
THEN, you need to put the key in, turn to run, put the ER brake on, and pull the
shifer all the way back to "1" to reveal the plug for that harness:
Ah ha!! Thank you sooo much!!![QUOTE=08'MustangDude;8641475]The dust cover, blind, and PRND321 are part of the assembly, and it comes off.
There are tabs that hold that on, you can release them and pull the that off. I tookmine off to paint it.
[/Q
ralphieparker
12-16-2011 10:27 AM
TOMMY01GT
05-21-2011 08:26 AM
