School Me on Proper Stock Radiator Fan Operation
Hey guys, my car is a 1995 GT model with the 5.0, but I'm posting in this section because I figure you SN95 guys will be more familiar with this than the 5.0 crowd, on account of electric fans being a '94+ thing. Anyway, I was thinking about how our stock radiator fans operate, and in an attempt to help clear out any misconceptions that I may have been developing, I turned to the Ford service manual:
The manual only states that the fan motor "starts" and "stops". It doesn't say anything about under what conditions one should expect to see LOW speed or HIGH speed operation. Both circuits are shown in the wiring diagrams, but that's only good for tracing the circuit. It doesn't help determine whether things are working properly or not.
It was my understanding (and please correct me if I'm wrong) that if the coolant temperature started to get too hot (like from a lack of radiator airflow due to sitting in traffic), the fan would come on at LOW speed. And if coolant temp continued to rise past another set point, it would trigger the fan to run at HIGH speed. I was also under the impression that A/C operation triggers the HIGH speed fan. But I can't seem to confirm or correct these assumptions.
The manual also includes a note about what you should see happening on the dash:
This has NOT been my experience. My gauge tends to keep the needle near the "O" in "NORMAL", which is in the lower portion of the gauge's scale. If the car is not moving, I can hear the radiator fan kick on as it gets close to the "R", and it keeps the needle below the mid-point of the gauge.
A few months ago, it developed a tendency in traffic to get close to the top of the "normal" range before the fan would turn on. I discovered that the fan was no longer working on low speed, but high speed still worked. The new fan works just fine on both low and high speeds, and my gauge is back to staying on the cool side, near the "O" in "NORMAL".
So is there anything about my understanding of the radiator fan that's in need of correction? In my searching, I found a thread where somebody claimed that the original tune in a stock T4M0 PCM (that's what I have) turns on the fan at "208 low speed and 224 high speed". That sounds about right to me. But why doesn't the manual specify fan speeds? Again, this is the 2000-page Ford manual, not a 400-page Chilton or Haynes book.
The cooling fan motor is controlled during vehicle operation by the constant control relay module (CCRM) (12B581) and powertrain control module (PCM) (12A650) which energizes the cooling fan motor under the following conditions:
- Engine temperature higher than normal. Cooling fan motor starts operating at 105°C (221°F) and stops when temperature drops to 94°C (200°F).
- A/C ON and vehicle speed does not provide enough natural airflow. Cooling fan motor starts running at or below 69 km/h (43 mph) and stops at 77 km/h (48 mph).
The system consists of a dual-speed cooling fan motor attached to the fan shroud behind the radiator (8005).
Normal operation and cycling of the cooling fan motor will cause the temperature gauge indicator to read:
- Between the mid-point and upper portion of the temperature gauge scale.
- Slightly higher indicator reading will return to mid-point when cooling fan motor operation begins.
...........So is there anything about my understanding of the radiator fan that's in need of correction? In my searching, I found a thread where somebody claimed that the original tune in a stock T4M0 PCM (that's what I have) turns on the fan at "208 low speed and 224 high speed". That sounds about right to me. But why doesn't the manual specify fan speeds? Again, this is the 2000-page Ford manual, not a 400-page Chilton or Haynes book.
So, I tore into it. Now have a great-operating fan and clutch combination which holds temp. nice and steady. If you care to see pics, just ask.
Not what I'm looking for here, but that is very interesting. I think you should post a whole write-up of that, when you get a chance. I saw a couple of pics in one of your other posts and I gotta admit, that mod deserves its own thread. If you post up specs for the spacer and everything while all that info is still fresh in your mind, I'm sure someone will have use for it.
