SVT Forums
problem with overheating
Old 12-14-2018, 05:14 PM
jweizer07
jweizer07's Avatar
Default problem with overheating
i am new here so here goes i have a 99 cobra 4.6L 4 valve ran hot did compression test all are at 175 except the two middle cyls. on drivers side. they were # 6 145 and # 7 .135.i seen white smoke out exhaust one morn but never seen it again and never ran hot. wife drives about 5 miles a couple days later said it pegged the temp gauge i am thinking blown head gskt . i bought a block tester kit will that tell me anything for sure or is there anything else i can check motor has about 60,000 miles need some help thanks
jweizer07 is offline
Old 12-15-2018, 06:59 PM
pure_kaos
pure_kaos's Avatar
What does the oil look like? What was the coolant level at after your wife noticed the temp pegged? Symptoms of a blown head gasket are:
  • White smoke from the exhaust pipe.
  • Bubbles in the radiator or coolant overflow tank.
  • Overheating engine.
  • White milky oil.
  • Fouled spark plugs.
pure_kaos is offline
Old 12-16-2018, 02:14 PM
jweizer07
jweizer07's Avatar
the oil is clean not milkey i put about a gallon of watwe in the overflow started the car and waited for the temp to get up to normal and tested the block with a block tester and it took a little bit but the fluid turned yellowish after a little bit i then shut it off and the overflow went down quickly and i havent done anything since then except put the overflow cap on it. it didnt run hot when i tested the block and there wasnt alot of white smoke either in fact the smoke that was coming out the exhaust disappered rather quickly lile it was condensation
Protokiller
06-16-2013 11:34 PM
mahkismahkis2002
11-25-2010 04:15 PM
david01130
09-17-2009 01:56 PM
96GTMustangCT
09-28-2007 12:51 PM
98slvrGT
04-25-2006 03:11 AM
Quick Reply: problem with overheating
