Rough Idle in Gear - Rough Starts
Old 12-20-2018, 03:52 PM
marty1966
marty1966's Avatar
Default Rough Idle in Gear - Rough Starts
Not sure if anyone can help or not - I have a 2009 Mustang V6 with 234,000 miles on it! Here is my problem: Sitting in gear at a stoplight or wherever it often goes into a rough idle. It vibrates the car, then comes out of it. I start the car close to 30 times a day. About 2-3 times a day it will start and immediately die. Like its starving for fuel. .I hit the key again and it fires right up. Local dealership couldn't find anything wrong. Stuff that has been replaced: Plugs, Plug Wires, Fuel Pump, MAF Sensor, EGR Valve, Air Filter plus a complete diagnostic check up at the FORD dealer. Any ideas?
marty1966 is offline
Old 12-23-2018, 10:31 AM
99GTvert
is my username.
99GTvert's Avatar
Moving to tech..
99GTvert is offline
Old 12-24-2018, 09:31 PM
JJHoover
JJHoover's Avatar
have you tried replacing the fuel filter, what about the throttle positioning sensor? is there an aftermarket tune? if so try uninstalling it then reinstalling the tune
JJHoover is offline
Old 12-26-2018, 08:17 AM
marty1966
marty1966's Avatar
Thanks! I think it has been a little while since the fuel filter has been changed. I kinda forgot about that. And I'll check that sensor, too. Thanks!
Old 01-22-2019, 01:05 PM
marty1966
marty1966's Avatar
The fuel filter did help a little bit but it still does it occasional. I'll try the sensor next. Thanks!
Old 01-23-2019, 12:15 PM
A dirty throttle plate could cause a rough or no idle situation. At idle the throttle plate is just barely cracked open. Any kind of buildup on the butterfly plate edge or the throttle body near the edge can reduce airflow. Most dealers overlook this. Take you air intake off at the throttle body and have a look at the butterfly. ANY blackness around the outer edge of the butterfly or on the throttle around the butterfly can be the cause.
Take an appropriate throttle body cleaner and spray it out. See if the problem is resolved.
UltraBlue91'
05-11-2016 08:03 AM
02Blackstallion
01-18-2013 09:12 PM
SXGT
10-15-2011 12:47 AM
jason15332
09-24-2009 08:54 PM
danomano
08-11-2009 08:55 PM
Quick Reply: Rough Idle in Gear - Rough Starts
