2015 GT Convertible rear passenger window
sorry if this has been asked and answered in a previous post, but is anyone else having this issue? When I put the top back up and roll the windows up the passenger rear window doesn’t go all the way leaving about an inch of a gap. I have to manually close it every time.
I had/have the exact same issue and had the dealer "fix" it, $150 later and it is somewhat better. I cant remember what they did, but I know there was no parts, just labor. I had this repaired at my end of season oil change, right before I stored it for the winter (in Wisconsin). So I only had a day to try it out. I was able to close the window after the repair, but a couple of times it took a several tries, almost like it needed a running start ad would slow way down before completely closing. If is still finicky when it comes out of storage in spring the dealer had better be willing to get it right.
easy fix go buy some silicone spray. Got mine at napa for $5. Spray the well where the window slides into the top. It's that simple. I would spray both sides. Another tip is always put the back windows up first.
again it will work in a pinch but I've already taken my car to the dealer and not sure if they did anything diffrent. No need to realign the window just spray on the silicone onto the upper window tract and that will fix it for you. This is a well known issue but Ford won't address it properly. I have a 2016 Gat Vert.
I had that same issue today with my rental 2018 GT vert. With my 2008 vert I have always rolled up the rear windows first, then the door windows, per the manual. I tried that today and both windows had gaps. I had put the top down and when I closed it I noticed the gap. Had to manually close the driver side even when I rolled all windows down and closed the rear windows first.
fastbackford351
12-13-2011 01:24 PM
