Oil and Oil Related Topics A place to post your oil related questions and comments
Oil turning black
Old 01-17-2019, 09:09 PM
jem00021
jem00021's Avatar
Default Oil turning black
Hi all,
I bought a 2018 EcoBoost mustang, after about 2000 miles, the oil was black, had the dealership do an oil chang with full synthetic oil, have about a little over 500 miles now and the oil is turning black, was wondering if this is normal with EcoBoost engines?
jem00021 is offline
Old 01-18-2019, 11:08 AM
Buck Sergeant
Buck Sergeant's Avatar
jem00021, there are many reasons why your oil is turning black. Instead of me taking up a lot of space, GOOGLE "why does synthetic oil turn black". This is very informative.
Buck Sergeant is offline
Old 01-18-2019, 12:07 PM
Color alone is not an indicator of anything wrong. How does the oil smell? If it's black and smells acidic or burnt then there's a potential issue.
Old 01-18-2019, 03:04 PM
08'MustangDude
08'MustangDude's Avatar
IF it also smells like fuel that early, there is a problem there as well...
08'MustangDude is offline
Old 01-21-2019, 02:19 PM
jem00021
jem00021's Avatar
Want to thank you guys for your response, I checked the oil, does not have a burnt, acid, or fuel smell, smelled just like regular oil, so not worried or paranoid about any potential issues, thanks again
jem00021 is offline
Old 01-21-2019, 04:51 PM
08'MustangDude
2000 miles, and black, is not abnormal for any car, let alone a turbo... It's heat,
but mainly soot that turns oil black. Since soot particles are less than one micron,
in size, they typically don’t cause engine wear. Human hair diameter is 60 microns,
and soot is < 1 micron, so...
Another misconception is, black oil means it's time to change it. Discoloration is a
natural byproduct of heat and soot particles, which are too small to wear out your engine.
The only surefire way to determine your engine oil has reached the end of its service life,
is to perform an oil analysis. You send some out, and have it chemically analyzed, that
will reveal the true condition of the oil, the presence of contaminants, fuel dilution and so on.
Well, you can't afford to do that time and time again, so just follow the OCI in your car's
owners manual. The truth is Synthetics can run upwards of 25,000 miles, and a 100,000
miles test was done on synthetic. By changing the filter, and topping off every 10,000, you
can get 100,000 miles before having to change all of it. Saturn did such a test, and the
2.2 Ecotec motor was fine.
Also, most people associate soot with diesel engines, but gasoline engines produce soot as
well, particularly modern gasoline-direct-injection engines.
Some oil additives are more susceptible to darkening in the presence of heat than others. In addition,
normal oxidation can darken oil. Just as a note, oxidation occurs when oxygen molecules interact
with oil molecules and cause a chemical breakdown, just like how oxygen causes a cut apple to brown,
or iron to rust, and, high heat accelerates oxidation.
Old 01-25-2019, 12:32 PM
MustangDude-epedia
Murphdog
01-13-2013 03:33 PM
klr05stang
03-24-2010 02:11 PM
Stangman70
07-13-2009 03:24 PM
92Mustang92
07-13-2009 11:20 AM
Quick Reply: Oil turning black
