Spec stage 3 clutch on stock car
Old 02-20-2019, 01:15 AM
Waleedkjaber
Waleedkjaber's Avatar
Default Spec stage 3 clutch on stock car
Hey everyone.
I found a spec 3 clutch new for a decent price including the flywheel. How is it going to be if i install it on a stock 2014 mustang gt.
Thank you
Waleedkjaber is offline
Old 02-20-2019, 04:47 AM
08'MustangDude
08'MustangDude's Avatar
Install as any other clutch, but the pedal will be stiffer...
08'MustangDude is offline
Old 02-20-2019, 08:49 AM
proeagles
proeagles's Avatar
If the clutch is hydraulic I don't think you will see much of a difference. Back in the Fox body days you would regret it for street driving.
proeagles is offline
Old 02-20-2019, 02:45 PM
08'MustangDude
I had an HHR with a hydraulic clutch, and someone put in a stage 2 or whatever, pressure plate.
The clutch was stiff, but I didn't know that till I had a new clutch kit put in, FACTORY, and the
pedal was twice as easy to push. There was no air in the line prior, I had it bled because it
was stiffer than I thought it should be. Well, once I saw the old kit that came out, I saw the
beefier pressure plate immediately. The guy across the street from me put a stage 3 kit in
his Cobalt, which uses the same motor and transmission as the HHR. His pedal was so stiff
after, the pedal assembly went through the floor... Yeah, it was rusted, and already bad,
but had he went factory, that would not have happened. So, he had it all welded up to "work"
then hurried up and sold it...
JUSTA6
07-01-2010 10:02 PM
cenotaph
12-02-2007 11:31 AM
apicia
07-11-2007 09:07 AM
saud alzaabi
03-14-2007 06:47 PM
stang8689
03-01-2007 06:45 PM
Quick Reply: Spec stage 3 clutch on stock car
